跳转到主内容
加入维修社区 - 创建账户
Machine cloth mover tooth
Cloth not moving due to defective tooth
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
That sounds like a problem with the feed dog (the toothed part that moves the fabric). Check whether the feed dog is actually rising and moving back and forth when you turn the handwheel.
If the teeth are worn or damaged, the feed dog may need to be replaced. Also check the feed-dog height and the stitch-length setting before replacing it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Krraj Kant 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 53
