跳转到主内容
加入维修社区 - 创建账户
2025 年 3 月发布的配备 M4 芯片的 13 英寸 MacBook Air 的维修指南、拆解和故障排除信息。
MacBook clicking and cracking
I recently cleaned out my macbook air m4 keyboard with my pc blower but now its making clicking and cracking sounds everywehre whether i open it or close it or press anywhere i treat it like a gem and never damage it. i need help please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If it started right after using the blower, I’d stop using it for now. A PC blower can be strong enough to shift something slightly inside the hinge or chassis.
Try opening and closing it slowly and listen for exactly where the crack is coming from. Also check that the bottom case screws are tight and the case isn’t lifting anywhere. If the sound happens even when you just press the palm rest or bottom case, I’d get it checked rather than keep using the blower.
这个答案有帮助吗?
得分 0
2条评论:
Im thinking of opening up the bottom case and cleaning it out to see if that fixes the issue
由完成的
@shayanashayeri I’d be careful opening it just to clean more. Since the noise started after the blower, I’d inspect the hinge and bottom case for anything loose first rather than blowing more air inside.
由完成的
添加一条评论
添加你的答案
Shayan Ashayeri 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 42
总计 55
