跳转到主内容
加入维修社区 - 创建账户
有关 Lenovo ThinkPad E16 Gen 3 的维修、拆解和故障排除信息。这是 Lenovo 于 2025 年 5 月发布的一款 16 英寸商务笔记本电脑。通过型号 21TF 和 21SR 识别。
Removing the back cover
I welcome an expert detailed explanation on how to remove the cover carefully so that I don't break any of the snaps. Detailed video would be greatly appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you! I will give it a try!
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @chas24362
Here's a video that shows how to remove the back cover.
Here's the hardware maintenance manual for the laptop. Go to p.61 (66 of 105 pdf) in the manual to see how to remove the back cover.
Here's a link to the Prying and Opening Tools available from ifixit.
The above information should help you to safely open the laptop
这个答案有帮助吗?
得分 1
3条评论:
The RED arrows by the set of numbers 2 & 3, what are the arrows depicting?
I assume the #2 arrow indicates to insert the pry tool and then push the top of the tool upward. is this correct?
I cannot tell what the #3 arrow is indicating.
Thanks for your help!
由完成的
@chas24362
#2 means insert the pry tool between the cover and the base to disengage the clip and then gently lift.
#3 shows all the points that have clips that need to be released by the pry tool
由完成的
I got it open! Thanks for you rhelp!
由完成的
添加一条评论
添加你的答案
Chas 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 85
总计 108
