跳转到主内容
加入维修社区 - 创建账户
大众ID.3是由德国汽车制造商大众制造的全电动小型车。
How to replace a 12V battery?
I want to replace the small battery myself. How do I do it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Service manual; https://www.vw-id3.com/volkswagen_id_3_e...
这个答案有帮助吗?
得分 2
添加一条评论
You can physically replace the 12 V battery, but the ID.3 is one where I’d be cautious about doing it as a simple DIY battery swap. Volkswagen says the replacement battery needs to meet the correct specifications and that the vehicle’s electronics need to be adapted after replacement.
The battery is in the front/engine compartment. If you do disconnect it, switch the car off first and disconnect negative first, then positive. When installing the new one, reconnect positive first, then negative. The tricky part is the battery adaptation/coding afterward, which is why VW recommends having a qualified workshop do the replacement.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rowan 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 73
过去 30 天: 193
总计 278
