跳转到主内容
加入维修社区 - 创建账户
2007 年至 2014 年生产的梅赛德斯-奔驰 C 级 (W204) 是该品牌的一次重大回归,相比圆润的前代车型,它更注重“坚固可靠”的制造质量和更锋利、更有棱角的设计。
Replacing downstream O2 sensor bank one passenger side
Hello everyone, I'm trying to replace the downstream oxygen sensor on my 2014 c300. I took it to my mechanic. We removed the plastics and we realized that the O2 sensor is placed inconveniently on top of the Cadillac converter which is very unaccessible. My question is that do we need to remove the exhaust like completely and how do we disconnect the sensor wires because they're placed behind the engine and there is no access neither from bottom nor the top. I feel like even if you do attempt to remove the exhaust we still wouldn't be able to reach the cable from the bottom. I watched a few videos on YouTube and most of them are removing the left side sensor or the ones that are removing the right side. The sensor is located conveniently at the bottom of the Cadillac converter which makes a lot more sense.
Any help is appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
On those W204s, the sensor itself is usually the easy part. The connector is the pain in the ass because it’s up around the rear of the transmission/bellhousing area. On the M272 C300, Bank 1 is the passenger side and Sensor 2 is the downstream sensor after the catalytic converter.
I’d try reaching the connector from underneath first with the car safely supported. Depending on how tight yours is, you may need to loosen/drop the exhaust a little for access.
Before tearing the exhaust apart, trace the sensor wire all the way to the connector and see exactly what’s holding you up. If the wiring and connector look good, then use a 22mm/7⁄8" O2 socket or wrench on the sensor. Don’t pull on the sensor wire to try to get it loose.
Also, if you’re replacing it because of a code, check the wiring and connector before buying the sensor. Those connectors can get contaminated or damaged and give you the same symptoms as a bad O2 sensor
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali E. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 14
