跳转到主内容
加入维修社区 - 创建账户
Craftsman 536.881800 汽油扫雪机是一款由汽油驱动的设备,旨在清除车道、人行道和停车区域的积雪。本页面提供了这款扫雪机的详细信息和维修指南,该系列包含不同排量的发动机型号(148 cc、206 cc、305 cc 和 342 cc)。
Engine rpm excessive when using
Engine rpm fluctuates or is not controllable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If the RPM is running away or fluctuating badly, I’d stop running it until you find the cause. A small engine overspeeding can do some serious damage. On these snow blowers, I’d check the governor linkage and spring first. Make sure the linkage moves freely and hasn’t come loose, bent, or been installed in the wrong hole. Also check that the throttle plate isn’t sticking.
After that, look for a vacuum/air leak around the carburetor and intake. A lean condition can make the engine surge.
Don’t try to control the RPM by manually bending the governor arm. If you can post a picture of the carburetor/governor linkage, we can see if something is out of place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary Howard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 37
总计 52
