跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
The display on my iPod is blurred?
for a while i had problems with my ipod. half of the screen was unresponsive to any touch but i left it . after being cracked & quickly fixed at a non-apple store it had a little opening gap between the upper left side. i was messing with it & squeezed it down pretty hard & when it got back on the screen was more as fizzed out like a tv screen. the side that wasnt working is still unresponsive to touch & i have the additional problem to the color & display. any one know how much it could cost it be fixed? or how i can?
https://discussions.apple.com/message/19...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
sarah, it sure looks like you need a new display assembly. The unresponsiveness is from a broken digitizer circuit and the distorted image is a broken LCD. Check here for the guides. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
Had a similar issue with mine, the display was flickering regardless of pressure on the back. i swapped the screen myself for under 60 bucks with no issues sense. I got mine from here.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sarah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 2,113
