跳转到主内容
加入维修社区 - 创建账户
梅赛德斯-奔驰 W126 是梅赛德斯-奔驰于 1979 年至 1992 年间生产的一系列 S 级轿车。作为 W116 系列的继任者,W126 于 1979 年 9 月首次亮相,是第二代正式使用这一尊贵称号的车型。“S-Class”是德语“Sonderklasse”(意为“特别级别”)的缩写。 W126 轿车最初提供直列六缸、V8 以及涡轮增压柴油发动机。其 C126 双门轿跑版本于 1981 年 9 月推出。
auto trans dip stick
I have an 84 merc 300sd. I can't get the locking cap on the trans dip stick to release so I can pull the dip stick.. I think it has a missing or broken part. I think there is supposed to be a lever that releases it. I just got the car so I'm not sure what the problem is. The cap will rotate and will pull up slightly but won't come out. Can I force it ? If so how? If I break it in the process of removing it, do you know where I can get a replacement? Thanks for your advise.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
On an ’84 300SD, I wouldn’t force it yet. There is supposed to be a locking lever on that cap. The black piece underneath the red cap swings up and releases the clamp around the dipstick tube. Once that lever is released, the cap and dipstick should come out.
If that little lever is missing or broken, that may be exactly why you’re stuck. I’d look closely underneath the cap and see if there’s a small black hinged piece you can get a finger under. Don’t put a pair of pliers on the cap and start twisting it yet; it’s old plastic and you’ll probably just make the job more expensive.
There are replacement locking caps available, and Mercedes owners have been replacing these for years.
One other thing: once you get it out, check the end of the dipstick. These old Mercedes sticks can have the rounded end broken off, which can make the level markings misleading.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tom campbell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 13
总计 13
