跳转到主内容
加入维修社区 - 创建账户
HP LaserJet 1020 是一款紧凑型黑白激光打印机,专为个人或小型家庭办公设计。它的打印分辨率最高可达 1200 dpi(有效分辨率),打印速度约为每分钟 15 页。它使用高印量碳粉盒,使其在处理基础黑白打印任务时非常经济实惠。该机型缺少无线连接或彩色打印等现代功能。
Paper not going in
I don't know what's broken but the printer tries three times to pull the paper and fails and then tells me there's no paper
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have an old hp laserjet p1102. Looks similar to yours. Getting a bit old (2005 vintage!) which means the rubber paper feed roller is hard and has lost its grip. If you can reach it (it's the oval shaped roller in the centre of the feed at the top) clean it with a rag dipped in meths or benzine. This often softens the feed rubber but isn't always a permanent cure.
Here's what I do when it tries to pick up the first paper in the feed deck (I hear three or four distinct clicking sounds as it tries to grip the sheet). I got myself a rubber finger tip which I use to gently push the sheet in while it tries to feed it making the clicking sounds. Once it takes the sheet, stop feeding it by finger. Also make sure your paper deck is not too thick or too thin, is stacked neatly and square and pushed in all the way into the paper take up slot. Once the first sheet is finger tip fed in and taken up and the rest positioned as above, the following sheets usually get fed in normally.
Each time you replace the stack, feed the first one in by finger.
In days gone by one used to get paper feed replacement parts for these printers. Maybe you can try - which is a long shot - else go for the cheap rubber finger.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
FaaMs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 47
总计 89
