跳转到主内容
加入维修社区 - 创建账户
适用于各类医疗实验室设备(包括医院和研究实验室)的维修手册和支持文档。
WPA Colourwave CO7500 Colorimeter Issue
Hi! Our school laboratory owns a WPA Colourwave CO7500 Colorimeter model which was working fine last school year. Today, we turned on the colorimeter and on the upper left, a "lamp" symbol appeared and keeps flashing. When we try to take a reference, it takes too long and doesn't show 0.00 Abs. How do I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @michellema58643
With the device turned on, press and release the Kinetics key (see image below) and check if the flashing lamp symbol stops and that you can then perform a test.
(click on image)
这个答案有帮助吗?
得分 0
5条评论:
Unfortunately even after I press and release the Kinetics key, the flashing lamp symbol still keeps showing up.
完成的
@michellema58643
Carefully peer into the cuvette compartment while pressing the T or R button, you may see a flash of light on the side of the compartment but if there no physical light seen then the lamp may have burnt out.
If it is determined that the lamp is the problem go to p.8 (11 of 13 pdf) in the owner manual to see how to replace the lamp.
Looking online using the part number quoted i.e. 80-3000-59 (examples) it's not cheap.
Is the device using mains or battery power only?
完成的
@jayeff The lamp does properly flash after I press the R button but the "lamp symbol" continuously flashes and does not give a 0.00 Abs reading. It just shows "---". The device uses a main power only.
完成的
@michellema58643
Can't find a service manual for the device so can only suggest that you turn it off and disconnect the power from the device and then press and hold the On/Off button for a full 30 seconds and then release it to see if this resets it.
Reconnect the power to the device, turn it on and check.
If still no good then there's a problem on the board but without a schematic etc I don't know.
完成的
@jayeff still didn't work :( prob an issue I won't be able to fix unless I open it up. Thank you so much your help! Really appreciate it
完成的
添加一条评论
添加你的答案
Michelle Makaluso 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 25
总计 25
