跳转到主内容
加入维修社区 - 创建账户
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
3d effect won't turn off
i opened the top case to clean the top screen and once i put the components back in, the 3d slider wont stay off.
the console starts in the minimum 3d effect, even if the tab is at the very bottom of the physical slider. if you turn the slider to max then back to off, the effect will turn off for a few seconds but then coming back to minimum 3d.
unsure as to what could be causing this, does anyone have an idea how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
You need to open it up again and make sure that the slider is inserted correctly. Make sure that nothing is blocked and that the black tab is indeed correctly inserted in the slider.
If possible, please share some pictures with us.
If this is the case, you might need to replace it completely to get it fixed again.
This is most likely a hardware fault.
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ezra Barrett (EZRA) 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 30
总计 77
