跳转到主内容
加入维修社区 - 创建账户
这是 2018 年末款 MacBook Air 小幅升级版的维修信息和指南,其型号 (A1932) 和 EMC 号 (3184) 均相同。此型号配备了原彩显示技术 (True Tone) 并对电池进行了微调。
Keyboard issues after battery chane
After replacing the battery I noticed the spacebar, G key, and comma keys are only responsive when I push down hard, the computer heats up, or I'm typing for some time. I assume that some of the adhesive got carried with isopropyl alcohol under the keyboard and is now affecting the keys. The other keys mostly work perfect except a few random ones that I noticed I have to click again. I tried putting a small amount of alcohol under the keys (broke my G key and got it replaced) but it didn't do much.
I really don't want to replace the keyboard, any thoughts or advice would be very much appreciated.
Update (09/15/26)
The battery seems good, its more the keys that are the issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Let's get a better view of things, install this gem of an app! CoconutBattery withe the charger plugged in take a snapshot of the Apps main window posting it here so we can see what it tells us.
由完成的
添加一条评论
1个答案
最有帮助的答案
The reason we needed to look at the battery is to see the health of the battery as a swollen battery can press against the keyboard causing issues like you reported.
Yes, the battery looks good so that only leaves how you mounted the battery. The adhesive sheet/tabs should have been thin did you alter them in any way? Did you have a hard time getting the battery out (the pulls didn't pull cleanly for you). Could you have bent the case half? And lastly, did you fully clean the case side of any remnants?
这个答案有帮助吗?
得分 1
1条评论:
1) alter sheets: no not on the new battery at all I just stuck them down
2) definitely had to work to get the battery out and then had to scrape the remnants off after (not of the battery just the adhesive strips that remained)
3) I don't think I bent anything
4) I did my best, there was some adhesive where the battery used to be but I figured putting by putting the new battery in the same spot that it would not cause an issue
由完成的
添加一条评论
添加你的答案
Cashig 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 54
总计 54
