Float attachment to switch arm
The float of my RJ50FE dehumidifier came off the end of the switch arm, and it isn't clear how it attaches. The float is a cylindrical hunk of plastic with an end-to-end hole through the center. There is also a "V" shaped wire clip with "L" bends on the end of each leg of the "V". The metal switch arm has a single hole near the outer end, just large enough for only one wire of the clip to pass at a time. The float has to deflect whenever the bucket is removed or inserted. How does the float get attached?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
