跳转到主内容
加入维修社区 - 创建账户
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Motor die's after running for short time?
While running my lawn tractor(model 917.289243 21hp Briggs and Straton 46 inch cut), after running for about an hour the engine stops. I've changed out fuel filter, changed the gas in tank, replaced air filter, replaced gas cap.
After engine stop there's no fuel in filter but full tank of gas { disconected the fuel filter going to the carb fuel run's with no problem's after hooking back up try to start nothing fuel filter empty? } there's two wires coming off the bottom of carb is this an electronic choke. At my wit's end, mowers only two years old warranty ran out three months ago started having problems one month ago go figure. Sears said they could send someone out for a $99.00 charge, to tell me what's wrong. I'm a disable vet with limited income so for now I'm hoping someone could help.
Chuck
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Chuck, take a look at the gas cap. Make sure that it is vented. It is possible that you develop a vapor lock on the mower. Reroute the fuel line from the engine as well as other places that could cause the fuel to gas off. Make sure that your fuel lines are in good shape and that they do not collapse. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chuck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 585
