跳转到主内容
加入维修社区 - 创建账户
型号:Cinema 600 型号代码:1068777 ASIN:B089B6VS11 UPC:743878043822 发布日期:2020年7月15日
Subwoofer not powering on
My Klipsch Cinema 600 powers on and works fine, but the subwoofer simply died. No light, nothing. I have verified the cord and outlet, both good. I opened it up looking for a fuse and I didn't find one. Any advice? Other threads are about the main unit power supply.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @jandsilentbob
If I've found the correct board there is a fuse on it.
It is a T3.15A 250V square plastic fuse.
Below is an image that shows where it is located. The fuse rating is printed on the board.
If it is blown, ensure that you get a T3.15A 250V fuse as a replacement and not a 3.15A 250V fuse. The T rating is important as it denotes that it is a slow blow fuse and not a normal fast acting fuse. A normal fuse having the same rating will blow immediately that the power is connected to the device due to the high inrush currents that flow whereas the slow blow fuse will hold until these currents subside. They last for about 4-8mS (milliseconds)
(click on image)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jandsilentbob 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 57
总计 57
