跳转到主内容
加入维修社区 - 创建账户
针对2026年13英寸MacBook Air的维修指南、支持以及故障排除信息,该机型搭载苹果M5 SoC芯片。发布日期为2026年3月11日。
My MacBook overheat at simple tasks
My MacBook is overheating on simple tasks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What Applications are you running and what services do you have auto running within bootup?
What is your RAM and Storage sizes and how full is the Flash NAND storage?
由完成的
添加一条评论
1个答案
What exact temperatures are you seeing, and where are you checking them? Also, what counts as a “simple task” (for example, browsing with how many tabs), and does the fan run loudly or does the Mac slow down?
First check Activity Monitor → CPU to see whether one process is using a lot of CPU, then restart and install any pending macOS updates. If it still gets unusually hot while idle, note whether it’s plugged in and whether the vents are blocked. A new Mac can run warm during setup, syncing, or indexing, but persistent overheating during light use may need service. If you can share a screenshot of Activity Monitor’s CPU tab and the Mac’s exact model/year, that’ll help narrow it down.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hania Khushi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 58
总计 58
