I brick my Phone
I was experimenting it with some custom OS and I downloaded the wrong regional firmware and loaded it. Locked the bootloader btw, now it won't accept any other firmware. What to do?
Hi @test75983
If you have a Win10/11 PC download and install this Rescue program. Open the program and select the Rescue tab
You will need to know the exact model number of the phone (or the IMEI number) and have a copy of the correct firmware for that particular model variant.
Connect the phone in Fastboot mode (Vol. Dn + Power) to the PC and click Rescue Now and follow the prompts
这个答案有帮助吗?
Well, as I told y'all.. I have tried every methods and it didn't work as Well...
Given your comment I'm now not sure if you've tried what I suggested above or not?
If you have and it didn't work, what happened?
@jayeff I did try it. It showed "Wrong firmware" something like dat and cancelled the process..
Have you verified that you've got the correct firmware for your phone and location (or for where the phone was first sold if now a different country)?
@jayeff welp, there's da catch... I tried custom rom for few months and then decided I will go back to Stock Rom and installed it's firmware manually (I didn't knew about Resuce Program by lenvo and Motorola) I installed wrong regional firmware and locked bootloader and now all I can open is bootloader.... -_-
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 97
总计 97
5条评论
Try searching 'unbrick Motorola G60'. There should be several sites with solutions.
由 F Dryer 完成的
@notbroken I visited service centre too, they told me WHOLE motherboard will have to be replaced.... And I tried every single things. Then my brother recommended me this site and I am here now...
由 Test 完成的
@test75983 Press and hold both the power button and the volume down button, if it still powers on and has Android. That should work to get the phone into Android's debugging menu. Otherwise try to connect it to a computer to try and manually erase the storage drive.
由 Theo Grefalda 完成的
@user5136121 Well, only Recovery section is working and if I try to boot in anything it jus' gives black screen and comes back to recovery....
由 Test 完成的
@test75983 I don't really do much with Android devices, so what does the screen show you in the recovery section? Is it a navigable menu? If so, use the volume buttons to navigate to a selection that says "Factory Reset".
由 Theo Grefalda 完成的
