跳转到主内容
加入维修社区 - 创建账户
Circulation pump ohm readings
wdf320padw0 dishwasher does not cycle after water fill. Pulled the circulation pump and 200 setting shows OL. But at 200k shows 89-96 ohms. Bought 2 new pumps and the same readings occur.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @abelsaiz
Looking at the wash/rinse strip circuit on p.4 of the tech sheet for the dishwasher, the wash motor should be 5-15 Ohms.
If you're measuring the wash motor directly on the motor terminals 1 & 3 with the harness wiring disconnected have you checked that you've got the correct wash motor?
According to Item #4 on p.13 of the parts list the wash motor part number is W10529161 which according to most suppliers has been superseded by W11133712 (example only)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abel Saiz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 37
总计 95
