跳转到主内容
加入维修社区 - 创建账户
Infinix Smart 8 安卓智能手机的维修、拆解和故障排除信息,包括型号 Infinix X6525 和 Infinix X6525D。
How to change display
Displays camera between in lagging
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Mavluda! If your Infinix Smart 8 display is lagging, try going into Settings, then Display & Brightness, and then Refresh Rate. Once there, select 90Hz instead of 60Hz if that option is available. The Smart 8 should support a 90Hz display, which is to make scrolling and animations smoother.
If it’s still lagging, I’d also try restarting the phone and closing some apps running in the background. If the lag happens even when you’re just navigating the home screen and settings, then it might be a software or hardware issue rather than the display setting itself.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mavluda Eshonqulova 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 47
总计 125
