Left Joycon ain't workin
So basically outta the blue it suddenly stopped working the pins on the rail and the Joycon itself seemed fine I tryed wiggling it around in the rail still nothin I tryed the sync button but also nothing and I had charged it yesterday also the lights never show anymore and whenever I tilt the stick down(specifically down) it fights the input and just nudges itself back to the middle even if I'm fully tiliting it downwards.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi!
So, since it does register inputs from the Joystick, means it still can connect???
I need to know:
Does it work wireless or only wired?
You can still charge it? So that means that the rail is still OK, correct?
Does any (left) other Joy-Con work on your Switch? This would be the ultimate test if it’s Switch or Joy-Con related.
Thanks!
由完成的
添加一条评论
