跳转到主内容
加入维修社区 - 创建账户
XV40 系列 Camry 于 2006 年北美国际车展上首次亮相,同期发布的还有混合动力版本,并于 2006 年 3 月作为 2007 款车型正式上市。
Air-conditioning temperature control issue
The automatic climate control system does not function properly upon starting the vehicle. The AC fails to blow cold air at standard temperature settings (e.g., 22°C / 72°F) and will only begin cooling if the thermostat is manually forced to its absolute lowest setting ("MAX AC" / "LO"). Once the cabin cools down under this maximum setting, the temperature can then be adjusted back up to a preferred comfortable level, and it will hold that temperature normally for the remainder of the drive. This issue occurs every time the car is started.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This can be an expensive, time consuming repair performed by repair shops or dealer, or by yourself if you are comfortable using service manuals and can diagnose, troubleshoot and use tools including a multimeter. You can always get an estimated cost from several repair shops and dealer otherwise you might consider it more expensive than its worth and accept this as a working solution on an aging vehicle.
由完成的
添加一条评论
2个答案
最有帮助的答案
Hi @vajirampap51825
Get the vehicle's OBDII port scanned with a scantool and check if any DTC codes pertaining to the Air conditioning system have been stored by the A/C amplifier module. The code will tell you what the problem might be.
You could always use the A/C self diagnosis procedure and check what that shows as well.
这个答案有帮助吗?
得分 1
添加一条评论
I am guessing that the max cool position bypasses the sensor. Why it starts working normally after that ??
You would likely do better on toyotanation.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vajiram papanaidu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 107
