跳转到主内容
加入维修社区 - 创建账户
How do you replace a failed speaker?
My speaker on my minimal phone MP01 failed after about nine months of use. The only thing that's been consistent and loud has been my alarm in the morning. I want to know if anyone knows how or has figured out how to repair the speaker on this phone without damaging it and what parts would be needed to do so.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Firstly Turn the phone off completely.Remove SIM Tray Use an ejector tool to take out the SIM tray.Pry the Shell: Carefully wedge a thin prying tool into the seam at the top corner of the back cover. Slide it around to unclip the shell.Unscrew the Body: Remove the two main screws holding the secondary inner frame. Note that one might be hidden under a small white sticker.Lift the Board: Gently lift the main board, watching out for the delicate antenna wires attached to the shell.Swap the Speaker: Use tweezers to lift the old speaker out of its lower housing, drop the new one in, and reassemble everything in reverse.
这个答案有帮助吗?
得分 2
1条评论:
I appreciate your response. I'll try that the only problem though is I'm not quite sure what the particular speaker is like the model number or anything to look it up by.
由完成的 分享
添加一条评论
添加你的答案
Willow Oakes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 124
