跳转到主内容
加入维修社区 - 创建账户
Currently lost of power
No power I don't know what happen it directly lost power since my last used
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@jundeewong Do you mean that the toaster itself doesn't have power, or does your whole house not have power? If your toaster does not have any power, then I suggest opening it up and changing out the PSU or power cord. If your whole house does not have power, then I would suggest that you either wait for the electricians to bring the grid back up, or change the fuses if the fuses for your home has blown.
由完成的 分享
添加一条评论
1个答案
If you didn't check you outlet ckt breaker, then my assumption would be, u can't fix it if I told you what the problem was.
However, assuming the breaker is tripped, then the issue might be a bad middle door switch or a worn mechanism.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jun Dee Wong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 101
