跳转到主内容
加入维修社区 - 创建账户
Skullcandy Air Raid 是一款于 2013 年 11 月 15 日发布的无线便携式蓝牙音箱,可从任何支持蓝牙的设备进行音乐流媒体播放。
Rained on while charging
I was charging it outside and it rained lightly for maybe 30 minutes or so and now the speaker won't turn on at all how can I fix itI was charging it outside and it rained lightly for maybe 30 minutes or so and now the speaker won't turn on at all how can I fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Rain can short circuit electronics, starting with water entry into the charging port. Whether this caused the battery to drain is one possible issue. Disassembly should be performed to wipe off remaining water, allow inspection of wiring for corrosion and damage to electronics. Tissues, cotton swabs and isopropyl alcohol can help with clean up. If you are successful in disassembly, leave parts exposed to dry out. Placed in a tray on top of a gas stove with its pilot light supplying gentle heat, in a gas oven with similar pilot light for heat or out in the sun. Warmth over several hours will help evaporate remaining moisture. Reassemble and try recharging. The battery may recharge and allow operation. Battery specs are printed on labeling. Click on the Guides tab in the upper right to open a new page and click on Battery Replacement to reveal disassembly procedures or below. Skullcandy Air Raid 电池更换. Hopefully, damage didn't occur, the battery recharges, and you restored your Skullcandy Air Raid back to full function.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carlos Cordova 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 31
总计 88
