跳转到主内容
鉴定方式: 型号 M8541 / 5 或 10 GB 硬盘 / 转盘会旋转
My iPod is not recognized by iTunes or the desktop?
My 10GB iPod Classic is not recognized by iTunes or the desktop. Tried everything including resetting. When I connect to my computer, all it does is make a clicking sound. Could it be the hard drive? If so where would I get a new one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
lindsym, if all you get is the rhythmic clicking, it does sound like the hard drive. You should get a message to contact Apple etc. on the display, but I would go ahead and replace the drive anyway :-) Just a quick warning, the HDD are not inexpensive. Check on here and I am sure you can find more places like it. Follow this guide for the repair. Also, you might want to consider replacing the HDD with a CF card. Check this answer for more information. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
I definately agree. I use a stethescope to listen to the ipod and
compare the sound against a known good ipod. Like oldturkey
says....rhythmic clicking is a bad drive because there is only
1 moving part in any ipod....the drive platters and read/write heads.
Normally, you can hear the platters spin...sounds like a whine.
You can tell it's a spinning thing from the sound it makes.
So if the sound is different - toast it is.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lindsym 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 691
