跳转到主内容
加入维修社区 - 创建账户
苹果推出的第六代智能手表,可选蜂窝网络连接,于 2020 年 9 月 18 日发布。 型号 A2376,44 毫米。
Reattaching screen after battery replacement
I just replaced the battery in my Apple Watch 44mm Series 6. The battery replacement went fine but I am struggling to reattach the screen. I purchased the Screen Adhesive along with my new battery but the adhesive I received was worthless - I didn't stick anywhere. I tried using E6000, which the repair guide recommended as an alternative but it doesn't feel as though the screen is securely attached. Does the screen snap in at all, or is it just the tape/glue that holds it in place? Any recommendations for securely reattaching the screen will be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hello,
It is only the adhesives that hold the screen in place. If you don't adhesive the screen down a lot, then the screen will come off, and you will loose all of your water resistance.
这个答案有帮助吗?
得分 1
3条评论:
Thank you. I'll try again.
由完成的
@jimstone You'll need to apply pressure after the screen is adhered on otherwise the bond would not be strong enough and it'll fall off after a few days(I learnt the hard way)
由完成的
Thanks. It is sitting with a spring clamp on it right now!
由完成的
添加一条评论
添加你的答案
James Stone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 31
总计 80
