跳转到主内容
加入维修社区 - 创建账户
Won't turn on
I have an older Danby, which I keep unplugged when not in use. When I plug it in, it beeps and the display shows for a second, then disappears. The power button doesn't turn it on. Unplugging and replugging gives the same result, a beep and a quick display of the last temp I had it set on, then it goes off again. Power button won't turn it back on. I've already tried the test and reset buttons on the power cord, which appear to be functioning properly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@trinklingcreek what is the exact model number for your AC?
完成的
DPA120E1BDB. I've already checked the owner's manual. There is nothing about maintenance or troubleshooting.
完成的
添加一条评论
1个答案
Hello, it looks like the motherboard is shutting down for some reason, since you're unplugging it each time you want to turn it off, maybe you're preventing the AC from starting a proper shutdown sequence, perhaps the fan has to keep turning for around 30s to prevent moisture or condensation to form on the motherboard or some electronic part.
I think a good start is to reach the board and clean it if possible or jiggle it, just don't forget to unplug the cord and becarful of the capacitors they still can hold charge.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Trinkling Creek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 40
总计 40
