跳转到主内容
加入维修社区 - 创建账户
DeWalt 空气压缩机 DWFP55126 是 DeWalt 于 2016 年推出的一款空气压缩机。DeWalt 空气压缩机 DWFP55126 维修页面提供了控制杆、歧管和泵的维修指南,以及调节器重建说明、技术和图解。
Compressor stays at max pressure
My DeWalt compressor regulator is inoperable and stays at max pressure. How do I replace the regulator?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Click on the Guides tab (upper right of screen page) to open a picture procedure on disassembly. Replacement parts may be needed.
由完成的
添加一条评论
1个答案
How do you mean? it either stops the pump at rated psi or it'll keep pumping and cycle the blow off valve over and over until the motor overheats and shuts off via thermal protection if you're lucky. If you aren't using the psi that's already in the tank and the compressor has been sitting there should be a pull ring on top of the let off valve, you pull that ring to safely empty the tank and also you shouldn't leave the tank loaded with air because there's probably water in there at the bottom of the tank and it can eat through and cause a failure you need to keep it empty when not in use and there should also be a plug for the water. The "regulator" is just a pre-loaded spring diaphragm and contactor switch that shut off the motor you can adjust the spring on it there should be a nut.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ed Macomber 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 23
总计 84
