跳转到主内容
加入维修社区 - 创建账户
发布于 9 月 16 日,苹果这款“小尺寸”旗舰智能手机配备了 6.1 英寸 ProMotion OLED 显示屏、三镜头后置摄像头系统、5G 功能,以及环绕在前置摄像头和顶部传感器周围的全新设计“灵动岛”。它是 iPhone 13 Pro 的继任机型。
Cellular RF front and scan test
I did a complete housing swap, and when I transferred over the charging dock flex connector the barometer must've been damaged by the alcohol as the diagnostic tool flagged the barometer and it was having a kernel panic. I've gotten a new charging port and it seems to be working fine, no panic. I did a diagnostics test and everything came back fine other than the cellular RF. what is this issue? Is there anything I need to check as far as connections?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Cellular issues can be very difficult to pin down because so many components are involved. But based on the fact that you did a housing swap, this is likely an antenna somewhere. This could also be an issue with the new charging port flex cable, as there are some antenna components on that assembly. But, honestly there are antennae everywhere. What happens if you put the old charge port flex back? Or at least connect it back to the board?
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the reply. I got another OEM pull charge flex and its working as far as all the testable components but still giving the cellular RF issue. it picks up 1 bar cellular occasionally then drops to SOS or no service. When it did pickup service, it was able to send a text and call, but data was hung up, not sure if that narrows it down any. Any tips or suggestions would be appreciated. Im already in the hole on this phone. The housing frame is a premium part 3rd party from MobileSentrix.
由完成的
So i was using a verizon ESIM and it was picking up the 1 bar and no data, but I swithed it to ATT sim and its getting full signal and speeds of 396mbps on 5G but still giving the Cellular RF flag in the diagnostics.
由完成的
添加一条评论
添加你的答案
CAB 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 66
过去 30 天: 291
总计 711
