Tractor loses power sporatically
Tractor loses power feels like starving for fuel
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Depending on age and gasoline used or using magic gas from store cans, you might have to remove and disassemble the carburetor from fuel fouling. This presumes compression is good and spark is correct. Gasoline with ethanol may result in moisture absorption, creating deposits clogging fuel passages in the carb. Miracle gas in a can from Home Depot, Lowe's, etc, may overwhelm engines with their concoctions that sometimes doesn't work and creates more problems than it solves.
由完成的
添加一条评论
