跳转到主内容
加入维修社区 - 创建账户
2012 年中款,A1278 / 2.5 GHz i5 或 2.9 GHz i7 处理器。
Fan Spin - No Boot - No Display
2012 A1278 Model on the bench.
It turns on, fan spins, but that is it nothing else happens.The sleep light is on.
I have tried, removing RAM, Swapping RAM, Without the KB connected, Without a display, different HDD / SSD, Different working HDD cable, Reset SMC, PRAM etc..... Board looks clean, no water damage evident. Owner siad it just wouldn't start anymore. It does charge the battery though.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
What's good Livfe? This sounds like the CPU might not be executing?
It could also be a corrupted Bios.
For the CPU:
Check:
  • PPBUS_G3H (~12.6V)
  • PP3V42_G3H
  • PP3V3_S5
  • PP5V_S5
  • PP3V3_S0 (after power-on)
  • CPU core voltage (VCORE)
If VCORE never appears, the CPU isn't being enabled.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, we will look into this and update with any findings :)
完成的
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 55
