跳转到主内容
加入维修社区 - 创建账户
经典 Xbox 无线控制器的第三次修订版于 2020 年 11 月发布,与 Xbox Series X 和 Series S 一起捆绑销售。 该控制器向后兼容以前的 Xbox One 游戏机和 PC。
Help, my controller doesn't stay connected wired
My Xbox Series X controller (Model #1914) seems to have a loose usb c connection since whenever I connect it via a wire it ends up disconnecting a lot. However, when I manage to get it charged (again cuz of the poor wired connection) and connect it to my pc via Bluetooth it works flawlessly.
How could I reasonably fix this issue without soldering if possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
Just asking (probably you already tried it): Did you tried another USB-C cable? Would do that first.
If yes and the issue continues, it's most likely the USB-C port... The downside is, that it need to be replaced and this requires soldering...
You could replace the board completely, but this will be more expensive.
Otherwise I advise to contact a local repair shop to do it for you.
Please let us know how it goes!
这个答案有帮助吗?
得分 1
2条评论:
Hello! quick update, ive tried it again but now the controller itself refuses to hold a charge (using the xbox plug and play kit) but stays connected wired sometimes
update on my update i pulled up the positive and negative terminals to tighten the connection up and it now holds a charge and when i used a new cable it seems to have made it work?? although it could be a fluke since ive tried multiple cables before.
ill probably just replace the entire board with the usb c connection anyways by buying a used controller.
由完成的
That is a good option as well!
Replace the board from the replacement controller. It could be battery pins related.. but those are also installed on the same board.
Please let us know how it goes :)!
由完成的
添加一条评论
添加你的答案
saviourr 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 57
总计 146
