跳转到主内容
加入维修社区 - 创建账户
这是福特 Escape 的第一代车型,一款紧凑型跨界 SUV。该车型于 2000 年开始生产,对应 2001 年款。
How do I fix obd code p0401
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It appears that code is for insufficient EGR flow.
Some solutions are
  • Use a vacuum pump and observe if it opens. If it doesn’t, the valve may need to be cleaned or replaced.
    • Clean or Replace the EGR valve.
  • Check the voltage at the DPFE, compare to specified values (refer to a manual for your specific model)
    • Replace the DPFE sensor (with a good quality / OEM one)
  • Inspect all hoses and tubes connected to the EGR system for any blockages or leaks.
    • Clean or replace hoses as needed.
EDIT:
It appears you want to know how to replace the EGR valve Egr valve replacement escape
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave O. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 29
总计 101
