Internal wiring/splice replacement.
I have a vintage Sunbeam Radiant Control T-40-1 toaster which has unfortunately suffered from a melted internal wire, probably due to poor insulation leading to a short.
I've purchased a replacement high-temperature wire, but I'm a little stuck on how to actually get the new wire back into contact with the heating element. Sorry if the photo isn't clear, but the end element is the coil at the top of the frame which is fed through an insulator and then immediately into the old wire crimp (or at least I think it's a crimp.)
How do I go about either removing the old crimp or otherwise making room to get the new wire where it needs to be? And then what would I use to secure the splice, would I solder it or use some sort of butt connector? Whatever I use needs to be able to survive the intense heat from being right next to the element.
Am I better off trying to source a replacement coiled nichrome element?
2条评论
I have a similar issue with a Sunbeam T-35 toaster. We are replacing the power cord (original started smoking a melted). When taking it apart, the short wire was no longer connected to the insulator. The short wire has a flat crimped metal end that looks like it should go into a flat slot in the insulator. How do we get it to stay in the slot? When we work with the wires to replace the cord, the short wire wiggles and will not stay in the insulator.
由 Kellie Turkisher 完成的 分享
@kellieturkisher Can you take snapshots and post them?
由 F Dryer 完成的 分享
