跳转到主内容
加入维修社区 - 创建账户
Bajaj Discover 是 Bajaj Auto 旗下的摩托车品牌。目前 Discover 有四种型号:Discover 100 DTS-Si、Discover 125 DTS-i、Discover 125ST 和 Discover 150 DTS-i。
Why long light not working
Patina long light not working why
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @nigusutegene
When you say "..long light..." do you mean the high beam headlight?
If you do, have you checked if the headlight bulb is OK. It is a twin filament bulb i.e. one filament is for the low beam and the other for the high beam. When the high beam is turned on, both filaments are lit.
If the headlight bulb is OK does the high beam indicator light in the instrument panel, turn on when you operate the headlight dimmer switch to turn on the high beam headlight?
If it does then if the headlight bulb is OK it could be a wiring problem between the headlight dimmer switch and the headlight.
If it doesn't turn on it could be a faulty headlight dimmer switch.
Here's the wiring diagram that may help if it's a wiring problem.
(click on image)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nigusu Tegene 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 28
总计 84
