跳转到主内容
加入维修社区 - 创建账户
Chevrolet Cruze 是通用汽车公司旗下雪佛兰部门生产的一款紧凑型轿车。Cruze 于 2008 年首次发布,采用前置发动机、前轮驱动布局。
Why does my car have code 68?
Hello everyone!
I have with me a Chevy Cruze 2010 with code 68 on screen and car won't crank or start, steering wheel is very heavy as well.
When I connected the OBD2 scanner, it says no faults code.
What could be the issue and how do I solve this ?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Asked two different ai systems with the same result.
Search Assist
Code 68 on a 2010 Chevy Cruze indicates an A/C Clutch Relay circuit error, which means the circuit is shorted to ground. This can prevent the car from starting and may cause heavy steering.
What condition is your battery in? Are battery cables and connections clean and free of corrosion? You can remove the ac relay and ac fuse for troubleshooting and see if your car starts up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Adawa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 32
总计 156
