跳转到主内容
加入维修社区 - 创建账户
2015 年 3 月发布的 11 英寸 MacBook Air 更新版采用了第五代 Intel Core i5 和 i7 处理器,性能和电池续航时间均有小幅提升。
No Internal or External Display Issue
Have a 2015 A1465 here (820-00164) that chimes / boots but there is no display at all. We have tested with another known display assembly & on external displays but still nothing. From what we can see we are getting readings from the outputs, but nothing, just a black un lit screen. GPU failure I thought gets a white screen. The fan is also at high speed. What can be? (I do believe that the technician has replaced the SMC 2x already).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Does the system respond when you use the system in Clam Shell mode you do need external keyboard and mouse here besides the external display connection. The lid must be down as the Hall sensor needs to see the lid is closed to enable the external as the primary display.
由完成的
@danj Will try it. And update as and when.
由完成的
Unite is dead, green light only, no fan spin, zero..... donor unit.
由完成的
添加一条评论
2个答案
Try connecting it to an external monitor but with the lvds cable disconnected
这个答案有帮助吗?
得分 0
1条评论:
@nik_one - Disconnecting the LVDS cable won't change anything here from a diagnostic sense. If the LVDS connection was corroded up then I could see that resolving a possible short.
Putting the system into Clam Shell Mode would be easier and offer a useful data point.
由完成的
添加一条评论
If you can get the external display to respond then you should be Ave to identify the system issue going into CPU Safe Mode. If you can't get into Clam Shell mode that points to a CPU module issue where the I/O chip part has failed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 109
