跳转到主内容
加入维修社区 - 创建账户
Apple 的主流 2020 款 iPhone 于 10 月 23 日发布,配备 6.1 英寸 OLED 显示屏、双 1200 万像素摄像头系统,并有五种颜色可选。它是 iPhone 11 的继任者。
What temperature is the device?
My device overheats a lot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I'm not sure which type of overheating you are referring too. During normal use any electronic damage inside the phone can draw battery power to it and cause it to over heat. If its bad enough then the device will shut itself off and turn back on. The screen will go black and then you see the Apple logo. This is because a sensor in the phone is causing the phone to shut off. Then it restarts itself and it will try again. If the boot loop is long enough you can get the crash log and it will give you the codes for why the phone is rebooting. That will indicate if you need a particular part replaced like the poximity sensor or the charging port.
You will get a temperature warning if the device temperature is over 95 degrees Fahrenheit. The phone will tell you it is overheated and it has shut down to let the device cool. This is caused from being in the sun, a hot car, or anything that will cause the overall temperature of the phone to increase.
这个答案有帮助吗?
得分 0
1条评论:
What do you expect the penalty to be for damage caused by the heat on the device?
完成的
添加一条评论
添加你的答案
mohhsd229@gmail.com 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 68
