Audio ports not working
So i think i fried my ports, and i believe because i did a stupid thing and plugged in a bad cable, and it kinda lit on fire, or like sparked/heat up, (this was the second time) but i fixed it the first time by plugging it into the motherboard ones (i have like 5 audio ports, one with the case, 3 without) but it didnt work this time. any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Hi @youdontnee33198
What is the make and model number of the PC or motherboard if it is a custom build?
完成的
i will go figure that out, give me a bit
完成的
@youdontnee33198
Are you sure you meant audio ports and not USB ports?
Never heard of a desktop PC motherboard with that many audio ports.
Usually there's a Line In, Line Out and Mic port and if it has surround sound there may be 3 more speaker ports for it.
On the case there's usually only provision for a headphone jack and maybe a mic jack (although it could be a combo jack i.e. headphones and mic).
完成的
添加一条评论
