跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 个问题 查看全部
How can I fix e74, best option.
ialready have fixed overheating lights, it now has heat sinks on the hana and othe chip with the microsoft circle on it, it has new thermal paste and new thermal pads on the underside of the board, i heated it for a while with a hairdryer, this &#^#!* gets hot!, and kept the x clamp metal thingts on because screws kept it on overheating lights, please someone help. should i use an x clamp kit or just reheat with a heat gun
? and what is the benefits of screws and washers instead of using the x metal clamps. xbox 360, ben q, 2007 make.
please dont refer me to using the ifixit rrod repair kit, thanks =]
my previous question:
Error Code 0132 HELP! Elite (Ben Q Drive)
thanks everyone for helping.(sorry bout spelling)
Ben
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
You haven't fixed anything, everything there is just considered a "band aid" fix as it's not actually fixing the direct problem.
To properly fix an e74 error you need a rework/reball station which can cost thousands.
The bad thing for you is there is no guaranteed fix, you cannot fix this forever even with a reball station. Reflowing with a hair dryer will not do anything as it cannot reach a hot enough temperature to melt, a heat gun can but again your not fixing the problem.
I'd take it to somebody who does this professionally or buy a new one. If you don't care about the xbox then go ahead and use screws/washers/bolts and a heat gun.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
wazzzat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,238
