跳转到主内容
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 个问题 查看全部
Rotor will not come off after pads and caliber removed.Are there some
The brake rotor does not come off after you remove pads and caliber.....is there some bolts on the back side of rotor holding it on. Your comments appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
If it is a two-wheel drive, it should just be slightly pressed on. Sometimes a hammer will do the trick and loosen the rust and grime that may hold it on. If it is 4X4 or AWD :) check for a snap ring on the axle shaft.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fred b 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 574
