TCL 43S525TAAA replacement backlight LED
I have a TCL 43S525TAAA or maybe 43S525-TAAA. It's backlight configuration is not the standard 43S525 (1 connector on each top middle and bottom strips) but rather 1 connector on top, 2 connector on middle, and 1 connector on bottom.
I no longer have the original strips as I had replaced them with 43S525 strips from ShopJimmy. So I don't have the part number anymore and TCL cannot identify specific parts for variants.
I was wondering if anyone could identify the part, or point me to a comparable one.
The strip from ShopJimmy is essentially identical (the caps on the LED, the LED spacing, the mount points, connector type) except there is no 2 connector strip. The 2nd connector is not merely passthrough as leaving it dangling doesn't do anything, so I'm doubtful I could just splice it into one connector and call it a day.
If it's relevant, the identifiers on the actual board connected to the glass are E202404 NPGN-150 19 0319 01 D104059REF-B-28 and TH950698AK17D103Y1MH 1923 ST4251D01-6 Ver.2.1.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
