跳转到主内容
加入维修社区 - 创建账户
FixHub 便携式电源站的维修和故障排除信息,该便携式电源站是 iFixit 的 FixHub 产品线的主要电源和控制界面。于 2024 年 10 月发布。
System Error Update Firmware?
This might be one of the worst updating features i have ever used. Not matter what i do. No matter what cable. No matter what version i cannot update my device to get it back to a usable state. Does anyone have any ideas on how i can get this soldering set back to working condition and not in a endless loop of failed updates
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I've forward your issue onto the iFixit team, hang tight!
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
Hi @dsad32, sorry you're stuck in this loop. We've seen this error before, what's usually happening is that the station's secondary processor didn't finish its part of the update, even though the console says it succeeded. That's also why switching versions doesn't clear the error.
Give this a try to see if it resolves it:
  1. 1. Put the station into DFU mode. Hold down the knob button, and while keeping it pressed, plug your USB cable into the rear port. The screen will stay blank, which is normal. If that doesn't take, you can also try holding the power button and knob together for 10 seconds and then releasing.
  2. 2. Use a USB-A to USB-C cable if you have one, and make sure it's a data cable, not charge-only. There's a quirk in the firmware that makes updates much more reliable over USB-A.
  3. 3. Head to ifixit.com/fixhub/console in Chrome, Edge, Brave, or Opera. Firefox and Safari won't work with the console.
  4. 4. Connect and update to the latest firmware, 1.5.0. It has fixes for this exact update loop. If it fails partway through, just refresh the console page and run it again one or two more times.
If you run through all of that and it's still booting back into the error, email us at support@ifixit.com and mention this thread. We'll help get this resolved for you.
这个答案有帮助吗?
得分 2
1条评论:
Unfortunately I have tried these dozens of times already and again when you posted. still same issue. I have emailed your support with this thread and supplied photos for exactly what I'm looking at. Currently my station is bricked
由完成的 分享
添加一条评论
添加你的答案
Cinema 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 41
总计 158
