跳转到主内容
加入维修社区 - 创建账户
How to remove pink lines from screen
My laptop screen has some pink horizontal lines at the bottom. How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ouch! Lines tend to be a damaged LCD panel. You'll likely need a new display to fix it. To be sure connect your laptop to an external display if the image there is the same with pink lines that you have a logic board issue otherwise you've proved the disp,ay is damaged.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luana B 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 10
总计 67
