跳转到主内容
加入维修社区 - 创建账户
Can I replace the SSD?
Is it possible to remove the SSD and replace it with a larger one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Yes, you can replace the SSD in the ThinkPad X1 Carbon Gen 12.
Your laptop supports up to a 2 TB, 2280 M.2 SSD. Your laptop only have one single slot for the SSD, according to the User Guide, page 8.
In order to change the SSD, see the following sections in the Hardware Maintenance Guide:
  • Remove the base cover assembly, also called the lower case, see page 56, section called "1010 Base cover assembly".
  • Replace the M.2 SSD, see page 59, section called "1030 M.2 solid-state drive and bracket".
If you prefer a more visual guide, iFixit does sadly not have one for this Laptop. But they have a guide for the similar ThinkPad X1 Carbon 9th Gen SSD Replacement. It is not exactly the same, e.g. the 9th gen has five screws securing the lower case, whereas you got four screws. And if you remove the battery for the replacement, your screws may be in other positions with another amount of screws.
Good luck,
Cheers
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Joseph Millikan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 43
总计 203
