跳转到主内容
加入维修社区 - 创建账户
Apple 14 系列的新机型采用与 Pro Max 相同的 6.7 英寸 OLED 屏幕,但具备 iPhone 14 的功能,包括双摄像头系统以及搭载 5 核图形处理器的 A15 仿生芯片。
Logic board replacement without screen removal?
Is it possible to replace the logic board without removing the screen to access the press connectors from the front. ( can I just press the logic board down onto the screen connectors from the inside?) I don’t want to risk breaking the screen if I can get away without removing it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Gordon,
Yes, it is possible; actually the iPhone 14 plus is designed so the motherboard comes out from the back, not the front. The repair guide I found for it doesn't require removing the display for a logic board replacement, so you don't have to worry about damaging the screen at all.
Manuals / Apple iPhone 14 Plus / Motherboard - Nobody Calls Me Chicken
The site is in Spanish but does have an English language option, but it's somewhat incomplete so it's best to use it with a browser like Chrome that will do translation. Otherwise their guides are complete and well written and will get you through the repair with no problem.
Good luck, and let us know how it turns out! And while you're at it, take lots of pictures and once you're done you can use them to add a motherboard guide to iFixit's collection. It's easy, fun, and will have the appreciation of the repair community.
Create a new Guide - iFixit
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Gordon Jerome 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 117
