跳转到主内容
加入维修社区 - 创建账户
JBL Tune 760NC 耳机(也称为 JBL 760NC)是一款配备主动降噪技术的无线耳机,音质清晰。它们轻便、可折叠,非常适合长时间佩戴聆听。
Why its Microphone not working
I can hear through my headphones, but my microphone isn't working, so I can't input sound. I'm only receiving audio output, with no microphone functionality.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
This can be caused by multiple issues.
First of, make sure that your microphone volume, or call microphone volume, on your device is neither muted or set too low, if you have such settings available. Also check that the app you're trying to use the headset with has sufficient permissions for microphone, Bluetooth and the like.
Otherwise, make sure you have sufficient Bluetooth device permissions for your headset. How to check this differs per device, but can typically be found by:
  • Entering Bluetooth devices / Paired devices menu.
  • Find and select the headset (or press more info).
  • Then check if you have allowed any available options, and do allow any and all options available, such as Phone calls, Media Audio, Contact Sharing, e.t.c.
Else, try to unpair or "forget" the headset, then re-pair the headset.
Make sure you're having the latest firmware / devices drivers.
Is there a companion app? If there is, check around in the settings for microphone settings or anything of the like.
Try out the headset on another device to discern if it is the microphones/headset that is broken, or if it is a software issue.
Another common technique is to fully discharge the headset (typically by using it until it turns off), and then charging it back to full battery again.
All these tips above are assuming that the microphones works. Have you recently dropped the headset, or gotten it drenched in water? Please respond and we'll see how we can assist you further.
Good luck,
Cheers
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nitin verma 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 120
总计 320
