跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad 3/3i 15ITL6 是 IdeaPad 3 系列的 15 英寸版本,基于英特尔第 11 代平台。该系列拥有多种不同的型号,在 CPU、内存和 SSD 配置上有所差异,但它们的维修过程基本相同。于 2020 年发布。
Laptop Backlight not working
My laptop backlight is not working, the laptop itself works and when i shine a flashlight at it i can see what it displays, i opened the laptop and (by following a youtube video where the same laptop had the same problem) i noticed the fuse for the backlight was missing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @marioskij
The backlight fuse is a 3A 32V type number is ERBRD3R00X
To verify that it is the correct fuse location that you're looking at, if the motherboard is an NM-D471/NM-D472 model, here's an image showing the location of the backlight fuse FV1. The top image is a zoomed in image showing the location and the bottom image is an image showing the entire board that you can use as a reference to verify.
(click on image)
Here's an image from the schematics for the board showing the backlight power circuit (+LEDVDD) to the eDP connector
(click on image)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marioskij 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 86
总计 353
