跳转到主内容
加入维修社区 - 创建账户
按照以下指南修理您的眼镜(眼镜或太阳镜)。
replace Wolverine safety glasses ear stem
How to replace Wolverine safety glasses ear stem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Cheap eye protection glasses use press-fit pins to hold the hinge together. Turn the glasses over and using a piece of drill rod (broken drill) of the needed diameter to tap out sitting on a forked anvil so the pin can pass but the glasses frame is supported you should be able to push it out.
Otherwise it's a screwed in pin from the top.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your answer DanJ. Unfortunately Wolverine safety glasses have a fixed hinge pin that can't be removed. I couldn't get just a stem so I bought a new pair of non-prescription Wolverine glasses on sale. I pried the replacement ear stem out of the glasses by working a pair of small jewelers round nosed pliers under the hinge shoulder. (Tweezers just bent.) Then I slid the stem into the thumb of a leather glove to protect the plastic and stop it from sliding down in my vise when I hit it. I had to open the hinge a bit with long pointed tweezers before lining up the slot with the pin and gently whacking the glasses temple with a leather mallet. Voila' I can wear my transition progressive trifocals again! I threaded a shoelace into the ends to catch them and stop keeping them on my head and not fall on the floor and break again! I wear them all the time because the field of vision is great!
由完成的
添加一条评论
添加你的答案
Meg Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 23
总计 119
