How to fix broken wire
How to fix my broken wire it only works when it is bent
Not much you can do to fix the wires, you really need to replace the full cable assembly. Depending on the device the manufacturer might offer a replacement cable or you might be able to splice in a replacement cable using a standard USB-C cable that meets the needed wiring requirements.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 48
总计 253
